I have made a practice of stopping Mach 3 to test the fit of a nut and then cutting a bit deeper.
As long as you don't move the slide manually or quit Mach or remove the piece from the chuck then Mach still knows where the slide is relative to the piece and will calculate the angle of the spindle using the pulse.
Try it on a practice piece first! |
