The circular leadin is an arc (quadrant arc usually) that starts outside of the profile. The pierce is done at the start of the arc, then the torch makes a semi circle to where the profile starts. The shape you are showing was not cut with a leadin. If it was then the kerf width settings are way wrong to produce gouge like that.
-James
__________________ James Leonard - www.DragonCNC.com - www.LeonardCNCSoftware.com - www.CorelDRAWCadCam.com - www.LeonardMusicalInstruments.com |
