Originally Posted by Allen123 That just has to do with the way the numbers come out on the dimension if they go along the X axis or the Y axis. Nothing to do with the Z values.
BobCAD is really only designed to dimension in a 2D plane.
Pin Man, Do you want to post your file? |
I ended up doing it the long way around, but basically I was trying to put some simple 2D dimension on this 3D model of some test equiptment that I designed. Here is the file.
