Old 04-28-2009, 08:12 AM
jpawelk jpawelk is offline
jpawelk is on a distinguished road
Are you certain that your machine has the rigid tap option? If the spindle encoder PPU is set to 0, that usually means that you do not have the rigid tap feature. You will have to use soft tap (G84) with a compression tap holder. If you would like to know if the machine has the rigid tap option please call Milltronics @ 952.442.1401.
