If you go to file>new and it has the option for new manufacturing file, you should be set. If it doesn't say manufacturing as a type of file then you will probably need an extention. I have programmed quite a bit in pro-e 2001 and wildfire and every machine that i have programmed on has been able to do manufacturing files. Just make sure that it has the correct post processor, pro-e seems to be a bit limited on post processors.
Jeremiah |
