  #11   Ban this user!
Old 04-27-2009, 08:54 AM
fineartlig fineartlig is offline
fineartlig is on a distinguished road
Smile
1. Originally I was thinking the forklift bars (if I had a fork lift) could go under the table (attached to the lifting points) and under a pipe through the column. 2. I don't have a drawing of the side view to confirm that would work. 3. Can you tell me how high the table is.? 4. I might be able to get a pallet lift that goes that high.
5.Where could I buy a lifting load leveler? or do I make one out of kindorf ( uchannel with bolt holes?
6. Or maybe 2" x 2" angles welded togather. Scares me the the lifting points are far below the center of ballance.
7. Do you think that a 4 ton engine lift attached to a load leveler frame and a padded collar around the column would work?
8. Or maybe the best thing is to hire some equipment handlers?
Thanks in advance.
David.Munson@FineArtLight.com
St. Louis
314-369-3913
