Thread: Todays Disaster
Old 04-23-2009, 01:28 AM
545Kurt's Avatar
545Kurt 545Kurt is offline
545Kurt is on a distinguished road
Todays Disaster
Hi Guy's
Been a while since I last posted. Previously I was having motor troubles which ended up being a failed armature. Thanks for the help on that one. I purchased a new armature and installed it and was back machining. I got about 5-6 hrs use out of the armature and the same problem occured. The motor turns slowly and will not speed up with the speed dial the motor gets very hot in a short duration to the point that it starts to smoke. The motor worked awesome during the first 5-6 hrs time period. I checked out everything again and came to the same conclusion that the armature had failed. I e-mailed the company that I purchased the part from and they sent a replacement under warranty. Cool. I put the motor back together and found the exact same problem right away. I e-mailed the company and they advised that I should check out the board. I took the whole unit in to an electrical shop in town and they found the board to be fine but the motor to have a problem. They found that the motor was drawing 7 amps and would not speed up. The guy at the shop said that the motor should draw about 3 amps at start up and drop off once it comes up to speed. We even hooked up the motor to a seperate DC power source and found the same problem. Here comes the bad part. Tonight I was doing some more testing just to make dam sure that there was no problems with my board. I was checking voltages on the board with the motor running and board literally went up in smoke. I guess the board had enough of trying to run shorted out armatures. After having a smoke myself to cool off I cleaned off all the black with some alcohol and inspected the damage. I found 4 burnt traces and several burnt components on the board. So here I sit with not only another bad armature but a completley fried board.
Kurt
