Some one could help me how to use the zero tool?
Taney reply: First count the thickness of the brass block, input the thickness value of the tool sensor into the DSP handle: MENU--MACHINE SETUP--C.A.D Thickness.
Then press MENU+ON/OFF togehter and relase the two buttons at the same time, the spindle will go down, when the tool tip touch the sensor the spindle will go up, and the system will remember the Z-0 point
