Originally Posted by ranchak Chris, I have 10cfm @90psi, it won't be perfect, but will definately work. The V2 "requires" 7.8CFM @80 so I will be close when you figure in the flow restriction with fittings. I'm going to use large vacuum reservoir tanks to aid in pulling down the vacuum. I also plan on using this system to hold some parts that I have to mill. |
That won't leave much CFM left over for anything else. It also means that you compressor will be running at almost 100%.
Why not use an electric pump with those same tanks? My Rietschle Thomas from Veneer Supplies needs new seals, but it has run (in always on mode) eight hours a day for the last two years. I can't imagine how a compressor would have faired after the same duty, a bunch of oil changes at the minimum; plus the compressor is much noisier.
Chris Kirchen
