When NX is installed the help docs should be installed as well. Get then installed.
Yes you can have polar coordinates. What version of NX are you using?
One way is the use the User Defined Event "Set Polar" - then the post will need to be set to output polar coordinates.
__________________ John Joyce -NC Programming Supervisor
Barnes Aerospace, Windsor CT |
