Chris, I have 10cfm @90psi, it won't be perfect, but will definately work. The V2 "requires" 7.8CFM @80 so I will be close when you figure in the flow restriction with fittings. I'm going to use large vacuum reservoir tanks to aid in pulling down the vacuum. I also plan on using this system to hold some parts that I have to mill. |
