Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fanuc > 5T/5M
Old 10-16-2008, 07:37 PM
bcbackoader is on a distinguished road
uncontroled start of spindle when "z" home.
We have a Fanuc 0M controler on a LeBlond Makino, maybe this is just a "blond" problem, but reciently we have had the the spindle starting up on its own.
For example, we may have halted the program, when the spindle has been sent home.
Several times the spindle starts up in the clockwise direction at 1200 rpm and sits there merrily spining away. If we leave it, then eventually it would try to stop, flip about in reverse for a bit, and then wind back up to 1200 again for a while.
If we take the z axis away from the "0" position, the spindle stops immediately.
One time it started up while the tool change arm was wrapped around the cat 50 holder, and that created a few sparks, and lively time for all.
|Basically, there is not running program, it doesn't mater what the next line or existing line commands are, the home led's on the controlller board are flashing as the spiddle is turning, indicating to us that it is able to see the index sensor. There are many adjustable pots on the right side of the board, but without the specific manual to go through step by step adjustments, we are sitting here a little stumpped...
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 01:15 AM
Lets Start 3-axis "khattak Mill" Khalid CNC Wood Router Project Log 46 01-14-2011 05:37 AM
"Home-made" V-groove rollers and rails Gerald_D Linear and Rotary Motion 10 06-14-2008 03:02 AM
Home Made "Junk Box" Power Supply emtffkev General Electronics Discussion 11 04-20-2007 08:11 AM
4020 fadal cant get past "Cold Start" chipsahoy Fadal 13 03-07-2006 07:29 PM
