Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fanuc > 5T/5M
Old 12-07-2007, 10:37 AM
john-shipman@ho is on a distinguished road
MDI ONLY 10 BLOCKS HELP!!!!!!
I only need to input about 10 blocks of data but I don't understand how to do it on this 5T the manual doesn't explain it very well. japenglish.
Old 12-25-2007, 12:34 PM
Dan Fritz is on a distinguished road
You can only run a single command in MDI mode. One M-code, one G-code (of each group), and a motion command is about it.
If you want to run 10 blocks, you'll have to use EDIT mode and key a short program into memory. That procedure is described in the 5T manual. Look in the table of contents for "Memory & Edit" or "Part program storage and Edit". It's in there.
What you need to do is erase the existing program from memory, key in each command and INSERT into memory, then RESET, shift to MEMORY mode, then press CYCLE START.
RFQ for maple blocks CNCadmin Employment Opportunity 8 04-10-2007 03:41 PM
WHere to buy Plastic Blocks?? carguy327 Glass, Plastic and Stone 3 08-03-2006 09:30 PM
Are THK Blocks interchangeable ericdwilso Linear and Rotary Motion 3 03-26-2006 05:15 PM
Blocks for Leadscrews Mcgyver Mechanical Calculations/Engineering Design 9 10-12-2005 12:04 AM
iko blocks seem too stiff. bgolash DIY-CNC Router Table Machines 4 03-14-2005 02:50 PM
