Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fanuc > 5T/5M
Old 01-26-2012, 01:25 PM
LSR_SERVICE is on a distinguished road
spindle not run M04 cammand
hi...
spindle run Jog mode or MDI mode ,not run program MO4 cammand in auto cycles
pl help me machine electrical diagram send,
NAKAMURA TSC-1
FANUC 3T CONTROL
LSR_service@oneindia.in
Old 01-26-2012, 07:56 PM
neilw20's Avatar
neilw20 is on a distinguished road
Try M-zero-4. Not M-OH-4.
or just M4.
Maybe this machine cant run spindle in reverse?
M3 forward.
M5 stop.
Old 04-16-2012, 08:17 PM
Frank1 is on a distinguished road
Hi
Not familiar with 3T , but have 5T. Spindle won't respond until MDI input M41, there after M03, M04 etc work. Might help?
Frank1
Old 04-16-2012, 08:26 PM
neilw20's Avatar
M41 is select gear, M42 is too, on an OKUMA lathe.
Some need G50 S1000 to set max speed.
If default is zero, then it is really hard to make thing rotate.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Need Help!- Mini Mill X2 Spindle Head + VFD + Chinese Spindle= custom! diyengineer General Metal Working Machines 8 08-25-2011 12:33 PM
Problem- mach3 spindle dro not working, spindle speed changing while jogging and running code jasminder Mach Software (ArtSoft software) 0 02-23-2011 12:12 AM
FANUC OT B Spindle rpm fluctuating and causing 1008 Spindle Drive Fault Bill Gillen Fanuc 4 10-15-2010 01:10 PM
spindle motor and spindle control dont work customcncparts Milltronics 0 10-01-2009 02:08 PM
Sweo spindle drive? new mill dead spindle Shizzlemah Fadal 13 12-18-2008 11:11 AM
