Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fanuc > 5T/5M
Old 08-12-2011, 06:27 AM
M.RISHIKESH is on a distinguished road
Fanuc 0iTC with Alpha i Drives
Dear Sir
We have got a Grinding Machine with Fanuc 0iTC CNC and alpha I drives, with FSSB communication
This machine has got 2 numbers of dual axes drives, first drive for X and C, 2nd drive for Z1 (ie Z) and Z2 (ie Y)
Error 368 : Y axis Serial Data Error (INT) appeared
When we interchanged cables JF1 and JF2 in 2nd drive, then Error 368 : Z axis Serial Data Error (INT) appeared, we did not find any problem in cable JF2 ie error 368 is due to faulty fanuc Pulse coder of the Y or Z2 Motor
We need to bypass Y or Z2 axis and for this, we changed Parameter 2009 bit 0 (DMY) for Y axis to 1, taken out JF2 from drive and put a dummy connector with pin numbers 11 and 12 short, now error 466 : Y axis Motor/AMP combination is appearing
Originally Parameter 1023 X = 1, Z = 2, Y =3, C =4
Changed Parameter 1023 for Y from 3 to -128
After power off and ON,, error 400 : Y axis VRDY ON, 404 : C axis VRDY ON and error C axis Digital Parameter appeared
Pl let us know on how to bypass one axis out of dual axis drive ??????
Best Regards,
M. Rishikesh
0iTC alan72 Fanuc 3 05-27-2011 10:43 PM
Need Help!- Fanuc Robodrill Alpha T10-B Adam@MSI Fanuc 1 01-16-2011 10:16 AM
Fanuc Alpha 0C EDM Wire garygilmour EDM Machines 0 01-30-2010 01:56 AM
Need Help!- FANUC 0itc TRAINING FOR LATHE? joesimmers Fanuc 2 12-15-2008 08:10 PM
CamSoft with Fanuc alpha servos cnc-it CamSoft Products 5 03-06-2008 09:16 PM
