Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fanuc > 5T/5M
Old 10-08-2010, 11:39 PM
quasarix is on a distinguished road
Post Communication RS-232 problem
Greetings!
My friend has old old machine EMCO CNC-330 lathe/turn that has Siemens or my guess Fanuc system 6 control (with Siemens servos).
Machine works good, but it has no regular display, only red diodes display.
My problem is i cant figure it out how to use communication RS-232 port.
Machine has read/punch/tape modes, but it just wont sent, i got parameters and all is set as it should be, as far as i know, but it doesn't react when pressing read/punch at all (tried in EDIT/MEM)
If anyone has some tips/help, i would love to hear it
P.S. Sorry for double post, i dont know where to post it because it has fanuc and siemens/emco stuff
Old 10-09-2010, 08:54 AM
tmbruno28 is on a distinguished road
first thing, tell me what is your software version, because RS232 is avalaibale only after on eold edition; i have to check it exactly at office
you can see youur software (number and version) at power on.
check your 7 segments displays . software must be 9hundred.....
Old 10-10-2010, 11:33 PM
ok will check and post here as soon as i can
Thanks for trouble
Old 10-14-2010, 01:35 AM
It displays shortly 994 27 and in next line 0000
Hope that helps
Old 10-14-2010, 12:24 PM
this software version is avalaible for RS232 with 2 conditions
Baud rate max is 4800
RTS/CTS is not controlled.
you need to make some modification on your PC/puncher PCB and to make a new cable on connector CSR, this connector must be empty now.
Old 10-14-2010, 12:46 PM
Al_The_Man's Avatar
Here is a few 6 notes on RS232, one from Dan Fritz.
Old 10-15-2010, 06:58 AM
Thanks guys!
i owe you
hope I make it work
Communication problem with X4+ shannow Syil Products 47 02-23-2009 04:43 AM
Newbie- some kind of communication problem JamsAirbrush Printing, Scanners, Vinyl cutting and Plotters 6 03-16-2008 04:25 PM
TNC 370 communication problem Flatdog Bridgeport and Hardinge Mills 3 01-09-2008 07:20 AM
Communication Problem LEGCNC Machine Problems, Solutions , Wireless DNC, serial port 1 05-29-2006 08:34 PM
Communication Problem Alex S.A Computers and Networking 2 01-28-2005 09:38 AM
