Hi everyone! I just acquired two new (to me) cadillac lathes with 5t's on them. I'm probably going to retrofit sometime, but as of current would love to just get them turning... I'm having a problem getting the lathe to do anything, the control lights up, but it seems noone's home. It wil kick the relays on the manual jog buttons, and the spindle drives, but after a couple pushes, it throws a servo voltage alarm, the spindle buttons kick the relays, but no motion or alarm... Does anyone have any clue what might be the situation? I was wondering if it might be the parameters, as that the battery that was connected to the control in question was hammer-dead. Also, is there only supposed to be a battery plugged into the memory board on the bottom? I saw a 5v input on the top board, on the right side, and was wondering if it should have battery power also. If a person needs more information, I'd love to give it! Just let me know what might help in diagnosing this problem, as that I thought i'm pretty adept in electronics and computers, but this thing is humbling me up pretty quickly... Thanks!!! -Parker Bender |
| Hi Sung! I am not getting many errors, it is mostly just not working. When it starts up, it displays 96 under the P/S area, and 02 above the 'number' buttons. When at idle, it displays the 'ready' 'Label Skip' and 'Battery' Led's If the feedrate is below 2ipm it will not cause an alarm at all. if the feedrate is above 2ipm, or if you press rapid along with one of the jog buttons, an alarm turns on, with a '1' under the S/V column. Is this meaning that the servos are stuck, or that there is a wiring problem? Also, my supply voltage is a little high, at 250 volts. can that cause this problem? Thank you very much for any help! -Parker Bender |
Do you have maintenance manual for 5T? I have the manual but it's japanese. If you havn't I'll send you. Can you send me PARAMETER List(No.00~49)? I wnat to check parameters. Good Luck. |
| I do not have the maintnance manual for it yet, but it is supposed to be in the mail, so I should have it soon. I'm not in the shop right now, so I can't get the parameters, but I will post them as soon as I get back to the machine. thanks! -Parker |
| Hi Sung, Here are my parameters: 00: 0111111 01: 0110111 02: 0111101 03: 0011111 04: 0111111 05: 0111111 06: 0111111 07: 0111111 08: 0111111 09: 0111111 10: 0111111 11: 0111111 12: 0111011 13: 0011111 14: 0111111 15: 0111111 16: 0111110 17: 0111111 18: 0111110 19: 0111111 20: 0111011 21: 0111111 22: 0111111 23: 0111110 24: 0011111 25: 0111111 26: 0110111 27: 0111111 28: 0111111 29: 0111111 30: 0111111 31: 0111111 32: 0011111 33: 0111101 34: 0001111 35: 0101111 36: 0111111 37: 0111011 38: 0111111 39: 0111110 40: 0101101 41: 0111101 42: 0111011 43: 0111100 44: 0101111 45: 0111111 46: 0111111 47: 0101111 48: 0110111 49: 0111011 Hopefully you can make sense of that, It doesn't seem to be blank, though, which makes me concerned that it is not the parameters making the machine not work. Thanks for any help! -Parker |
| Hey Sung! I don't see anything in my mail, and was wondering if you had already sent those parameters, or if you hadn't. If you already sent me something to my mail, it must have been the wrong address. If not, no big deal, just checking. Thanks again! -Parker |
#10
| Hello Sung, I still have not received anything, do you have the correct address for me? My email is: parkerbender(at)hotmail.com Thanks again for all of the help, and I apologize for the confusion, -Parker |
| 3 Cadillac CNC Lathes starting at $100 | WayneHill | EBAY ADS | 0 | 02-02-2010 10:40 AM |
| DNC Large Files 12 MB and bigger Problem | Rocko1 | Haas Mills | 0 | 07-14-2009 12:09 PM |
| Need Help!- Cadillac Lathe? | NewNew | General Metal Working Machines | 1 | 07-09-2008 11:08 PM |
| Need Help!- 14" swing Cadillac metal lathe | NewNew | Want To Buy...Need help! | 0 | 07-09-2008 07:04 PM |
| Parameters problem on SCM Routron | claucampan | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 08-10-2006 02:25 AM |
