4th Axis Help
Results 1 to 2 of 2
Thread: 4th Axis Help
    Nov 2013
    Default 4th Axis Help
    Hello all,
    I recently acquired a Nikken 4th axis indexer with a Fanuc servo with incremental encoder, and aditional servo amp. I have everything up and working, but when comanded in MDI to make a move it is always incremental. any degree commanded even with a G90 will always add the degrees to where its currently positioned instead of going directly to that degree. I have combed through all of the parameters and cant find any that would change this. My control is a Fanuc OM-C. Any Ideas would be greatly appreciated.
    Jul 2010
    South Africa
    Default Re: 4th Axis Help
    change prm 29#5
4th Axis Help
4th Axis Help
