Fanuc 5T spindle drive blowing fuses
Results 1 to 11 of 11
Thread: Fanuc 5T spindle drive blowing fuses
    Dec 2007
    Mexico
    Default Fanuc 5T spindle drive blowing fuses
    Hello,
    I have read a lot here before posting this thread but the threads I found did not help completely.
    I have a Mori Seiki SL-3 with fanuc 5T which was working just fine and all of a sudden started to blow 2 out of the three 75 amp fast blowing fuses. Since those fuses are really expensive someone adviced me of using regular ribbon fuses just for the purpose of testing. First I used 60 amp ribbon fuses and I ended up with 2 scrs blowed up just as Al the man said I would happen in one of the threads I read. Then and after getting new scrs I tried 30 amp ribbon fuses and it works for a while, maybe a day or two( sometimes less than that and blows the fuses again. The I decided to disconnect the DC motor and install 50 amps fast fuses and the result is that it blows the within the hour having the motor disconnected.
    I am running out of ideas and any help would be really appreciated.
    The spindle drive model is A20B-0008-037 and it blowsthe second and third fuses (connected to S and T lines)
    jolulank
    Dec 2003
    Quite possible the firing board is causing the problem, with SCR spindle drives it is a gamble if you replace the SCR's without having the drive board checked, trust me, it cost me a $$ before I discovered this.
    Dec 2007
    Mexico
    Thanks Al, I will look into the firing board. I am not good at fixing cards but I have a guy that does fix them relatively easy.
    Sep 2010
    france
    firing problems can be check as follow
    check in CH17 (a,b,c) with an oscilloscope. If wrong, exchange AOS04
    check in CH18 (a,b,c) if wrong, exchange AOS03
    if problem occurs not at eatch time, first exchange AOS03
    Dec 2007
    Mexico
    Quote Originally Posted by tmbruno28 View Post
    Bruno,
    The CH17 (a, b, c) are next to the AOS03 and the CH18 to the AOS04. Just to be sure, if CH17(a, b, c) wrong, Do I change AOS04 like you said?
    jolulank
    Dec 2007
    Mexico
    Thanks for the help Al and tmbruno,
    It is working again. One of the hybrids A-OS03 (synchronous signal) was bad, it was replaced and now is working fine
    Thanks again
    jolulank
  7. #7
    Mar 2011
    CRO
    dear forumers, I have same problem as you with, A-OS03, A-OS04 hybrid, I can¨t find where to buy, if anybody can help , please contact me, I am from Croatia ..
  8. #8
    Oct 2006
    MEXICO
    What manual did you get the firing sequence and readings. What are the readings. While it is in command mode or stand still ?
  9. #9
    Sep 2010
    france
    Smile no manual....
    i don't have any manual for this spindle drive,
    only about 22 years of experience
  10. #10
    Nov 2011
    United Kingdom
    Default Re: no manual....
    Hi All
    I think I have same problem, gradually got worse now blows fuse top left of drive spindle board, anyone know where I can get the A-os02 and A-OS03 I.C's
    Ian
  11. #11
    Dec 2007
    Mexico
    Quote Originally Posted by mariineguyuk View Post
    Hi All
    Ian
    On EBAY,
    search for
    NEW FANUC HYBRID IC A-0S02 and NEW FANUC HYBRID IC A-0S03
    jolulank
