Old 01-11-2005, 07:17 PM
marx911 marx911 is offline
marx911 is on a distinguished road
die grinder w/ cutoff wheel clamp the motor down power up the motor and spin it at 200 or so rpm start your cut ( will be nice and straight) cut 1/4-1/3 the way thru... shut down the motor and the starting cut will guide you thru the rest leaving a nice straight cut ...make sure you are at a comfortable place and dont let the cutoff wheel get in too deep while its spinning so it wont bind.... be careful and its worked many times for me .... when you are done fire up the motor drag a file across the end and chanfer .....not OSHA approved ....but works good
Mark
