Old 01-11-2005, 06:52 AM
MIKE JEFFERS MIKE JEFFERS is offline
MIKE JEFFERS is on a distinguished road
hiedenhien uses m code not g. its basically similar and from a beginners point of view
a lot eisier to manually program. if your using a cam system (i use dolphin) use the
TNCnnn POST nnn being control number (tnc150/151 etc) these are fitted to interact
mills ,try heidenhein web site for more
m codes you need most are m3,4,5, spindle start cw- ccw- stop & m25 -spindle stop/z retract, cutter comp RR & RL right/left os.Rads are CC circle ctr CE circle end. cycl def button gives cann cycles.And thats about it the rest is simple co-ord programming.hope this helps
mike
