Hi Brad,
The connection is on the DSP breakout board inside the control box, I am not sure what machine you have but I suspect most of the breakout boards are similar.
The photo shows where the DSP breakout board. I think you will be best to check there first. The DSP pdf is too large to upload here so I have emailed it to you.
I am heading over to my workshop very soon, I will check exactly which connections are used on my machine.
Shannon.
__________________ Excitech 1530 Router owner,
WWW.REMAIN.CO.NZ. |
