Old 04-11-2009, 11:50 PM
youngjim youngjim is offline
youngjim is on a distinguished road
More questions!
Right now I want a G0602 lathe, and probably an X3-pattern mill, although getting either out here in the boonies will be a challenge, no doubt. I should explain a little bit of my thinking about the electronics:
The idea with a G-Rex, servos, and ballscrews was to go for (ethernet rather than parallel port) performance and expandability to a 4th and eventually 5th axis for the mill, and an ATC or live tooling for the lathe. Maybe even a drive servo for the spindle for turning polygons...
If was to go with steppers and leadscrews, the machine would be slower, but it would be substantially cheaper. If I did that then I'd simply build a PC for each of them, they're dirt-cheap these days. I know I could mix and match (servos for leadscrews, etc.) but I'd prefer to either spend the money on a balanced set of high-performance parts, or on a set of lower-cost parts rather than end up with an inefficient hodgepodge.
I read a thread in the yahoo gecko group to the effect that the G-Rex won't be developed any further. If this is the case then making a part looks like this, I think:
Some manner of CAD app (possibly T-Flex) eventually,
OneCNC for basic CAD and CAM (eventually, and before I bother with T-Flex),
Mach3,
Possibly a Smoothstepper to get away from parallel port timing limitations (worth it?),
Drives,
Motors,
Leadscrews/Ballscrews.
My overall intention is here is to gain the capability to make useful parts. I enjoy the idea of putting things (i.e. the retrofit kit) together myself, and I am inspired by all the mods and special tools people have come up with, but at the end of the day I want a reliable means of going from an idea to a part. I don't mind spending the time and money to get the right parts, but I want to start from a properly tuned machine and work out from there.
For instance, if I have the choice between lead and ballscrews, then I'd get ballscrews; might as well make it the best it can be the first time. Ditto the servos, if it is a matter of choosing from Gecko's catalog. After that, Mach3 is good (and cheap) enough that I don't have to think about that one, although I won't buy it until I try EMC2.
So I think I'm getting closer to a plan that looks like this:
Get the mill & lathe first, probably at the same time if I have to drive a day and a half each way to get them. Then a basically useful set of workholding tools, cutters, measuring tools, etc. After that, start on the CNC parts. I'm ok with buying a kit (CNCFusion's for instance) because any money I'd save in buying parts individually I'd burn up probably twice over on shipping and fees. (!)
I've got some time to plan this properly, and I know enough to know that I don't know nearly enough yet!
Jim
No time to do it right, plenty of time to do it twice.
