Ok, I've moved forward on this issue thanks to all the help. Now, I think i've come to the point where I need a post for my solidowrks-windnc-fagor 8055 sequences. I'm running an 13x48 trueturn mill (bridgeport knockoff) with the 8055i and apparently the reason my soft limit keeps erroring out is because the G code is whacked. There are G codes and the syntax appears correct, but the moves that the codes are telling my mill to do are out of range. So, I'm left thinking that I need a post to convert the g code to make sense to my 8055/trueturn machine. So, anyone have a suggestion as to where I might find the correct post? I am fairly new here and I understand G code in concept, but I'm no where near knowledgeable enough to crack the post issue on my own. Like I said, when i look at the graphic of the part I just downloaded from windnc, it's all over the place. Let me know if I'm off, here. Thanks again, for any help and suggestions.
Best regards, |
