Hi
Well to my experience here in the uk. Small welders are not very good under 160. If you aren’t experienced at welding you will blow the pipe.
But how about drilling the flange the size of the pipe then fit the pipe into the flange so that the pipe is flush with the flange face. Then you can run a heavy weld then grind it flush. This way the flange and pipe are burned in together. |
