Beege,
That's exactly what I had to do. The files are in my root Cadkey folder. They are ".exe" files that only work at the command prompt (DOS) level. Boy, this is a real flash back! For some reason when I try to do it as a batch using wildcards, it errors out after only 3 or 4 files. I will probably end up doing them individually but at least I can get them.
FYI, they won't run on a 64-bit machine but we still have plenty of 32's around.
Thanks for you help!!!
__________________ Doug Pryor
David Wolfe Design, Inc.
Akron, OH
www.davidwolfedesign.com
depryor@davidwolfedesign.com |
