g28 h0 will send the c axis home on most fanuc's control that i have worked on
h is the incremental call for the c axis.
if you are milling on the face of the part you WCS should be set to D+Z+ and your Cplane & Tplane should be Right. if you are using the caxis tool paths in master cam the software automatically sets those for you. if you are using the milling option in the lathe you have to set those your self by opening the planes window in the toolpath parameter.
__________________ If you can ENVISION it I can make it |
