Thread: Need more help
  #11   Ban this user!
Old 04-06-2009, 09:50 AM
TOTALLYRC TOTALLYRC is offline
TOTALLYRC is on a distinguished road
Originally Posted by scrambled View Post
Mike-
I am planning on using 1500 watt power supplies for the larger drives. I am using the 1000 watt for the smaller drives. I am waiting on the other power supplies because they are on backorder.
Any idea on what I should do or try? I am open to any suggestions.
Thanks for your help
Steve
From my prior post, get an amp meter and see at what amperage the servos are tripping the overcurent settings at. It could be that you have the curent limiting incorrectly set or the drive has a problem.
If you don't have acces to an amp meter, temporarily increase the current limits to there max and then see if the motor has any more power.
Just be careful and don't forget to set them properly before using the drives for real.
Mike
