Old 01-08-2005, 11:16 AM
jhowelb jhowelb is offline
jhowelb is an unknown quantity at this point
There very well may be, however, it's so easy to get started. example: I welded tohether a cube (just the edges) from angle iron and fitted the floor and walls with fire brick. (available at a masonry supply) and then a matching sized picture frame for a lid also fitting the brick in that. I cut a vent hole in the top and one side with a hole saw.
Then used propane weed burner to supply heat. A cast iron "lead pot" made a cruciable.
NOW! Go buy the books to get a good grounding in safety proceedures and an understanding of the dangers involved. Molten aluminum os HOT! AND must be handled with caution, to say nothing of the fumes created!! Good luck, have fun....BUT.....BE CAREFULL!
