HI
I use ezcam v16 pro for every part or work step (yes even making a zigzag on a flat surface) for heidenhain and fanuc.
it is fast and easy especially the new path generating engine from interfacial that they use is very strong and effective .
when you have dedicated toolnr in your machine ,you only have to choose the kind of tool you want to use from you're tool library and the speeds and feeds and pos NR are there .
the newest version has a wizard that leads you trough 3 stages (roughing,re roughing and
finishing)where you fill in kind of tool and how deep you want to go the rest is automatic.
but it is also easy to fine tune you're strategy
for the drawing part of ezcam. it is simple and very straight forward there are just enough buttons to draw lines. but some programs have some many possibilities that that makes it al to confusing fore me, i even make solids
although i don't think it is just the program for that.(it is ezcam not ezcadcam)
i would recommend this for everybody,except for tool-shops in the direct neighborhood
greeting bertus.nl the Netherlands
