Hi i have a roto zip saw that i use for high speed i made a clamp to fit around the mill spindle and the roto zip spins 30k works great for engraving just watch your depth of cut or you will snap of your bit. Good luck you can also put a router speed controler in line to cut the speed down if you need. |
