Old 01-07-2005, 07:01 AM
machintek machintek is offline
Moderator
machintek is on a distinguished road
An Error 4000 Is A Axis Drive Fault. Check The Drives In The Black Cabinet On The Right Side Of The Machine. Each Has A Red Led To Indicate A Fault Or That The Drives Are Off. Have Someone Enable The Drives And See Which Leds Go Off And Which Stays On. You Will Have About Half A Second. The Drive With The Led That Stays On Is The One With The Fault. Remember That It Can Be The Motor Or Drive Or Cable. The Drives Slide Out. Exchange Two And See If It Follows The Drive Or Stays In The Same Axis. If It Follows The Drive, It Is The Drive. They Are Fragile Electronically.
George
