Originally Posted by 307startup What I'd like to see: Panels for a full enclosure, optional ATC, integration of the CNC Brain...price point at HALF of a Haas SuperMini.
What are the base castings for this unit? What's the spindle taper? What are the travels? What's the price? |
Panels for the full enclosure in process.
ATC is optional
CNC Brain can be utilized with ease. I am using the New Industry Controls motion control board. It has 8 I/O's already on the board PLUS an opto 22 connection so I/O is only limited to the number you want to buy and the amount of space in your electrical cabinet.
Price point - $10,000 for the machine with a 0-5000 RPM (30 taper) or 24,000 RPM with an ER20 collet nose. ATC is an option and well below the other guy.
Travels -
Model
MK1 (designed for use with a 6" 4th axis and 5th axis rotating spindle) X-12" Y-6" Z-12"
Model
MK2 X-24" Y-12" Z-16"
THANKS !!
Kirk
