Old 01-06-2005, 07:58 AM
mikewsk2 mikewsk2 is offline
mikewsk2 is on a distinguished road
what type of radius cutter? they have bullnose endmills already included in the toolstore. If you want a corner rounding endmill then you will have to make it in the toolstore> Under tooling on the Geometry tab there is a small EdgeCAM icon on the lower right hand side> hit this and it will fire up a session of EC that you can draw the endmill.
Also, you can draw it in Inventor (or any solid program) as well. Just save it as an STL and you can browse to it from the Geometry tab as well. Just have it in the correct orientation on the solid side.
