nlh,
There is an option in the Z-Level Rough to convert the movements into arc segments. On teh posting page there is an Arc Fit option. Click the button so that it is depressed, and then compute and post the toolpath. You may want to play with the Tolerance, to get more or less arcs, but the option is there.
The HS Pocketing is a 2-2.5D operation in its' current state, so it can't be used with solid geometry. You need to instead use wire frame. If you can pocket this part that you are talkinbg about, and then follow through with a Z-Level finish, then yes, this toolpath operation would be of benefit to you.
Regards |
