GD5362,
The Cutmasters (Thermal Dynamics) do not have the Fine Cut consumable technology.....so the best bet is to just use the smallest nozzle available for the torch....and try to emulate similar cut conditions that I posted here for the Hypertherm unit. The kerf will be wider, there will be a little more warpage and dross....and shorter consumable life....but you should be able to get close.
Once you get it I will try to help....but I am a 31 year Hypertherm guy and the technology is a bit different! Or...you could change your order and replace the Cutmaster with a Powermax!
Best regards, Jim |
