Old 03-28-2009, 10:32 PM
slashmaster slashmaster is offline
slashmaster is on a distinguished road
Originally Posted by JWB_Machining View Post
idk about cutting wood but if it's your first set I'd say get a 1/8" - 1/2" off HSS Flat bottom 2 or 4 flute end mills. Because its your first set the cheaper the better because you're most likely going to break them and since you don't care about speed it just makes the most sense to get HSS in my opinion. If there's a good deal on a set of Solid Carbide definitely get em but idk what prices you're looking at. I'd check eBay if anything and try n find a lot of end mills for cheap, even if they're not so great imports you'll be much happier after you break and wear down a bunch because you were learning that you saved money instead of shelling out extra dough only to break the tool just as fast anyway.
Thanks JWB_Machining, so I should practice with cheap endmills first until I have a clue.
