Right angle drilling m3 holes in enclosure | | I am a bit stuck on how to drill 90 degree holes in an enclosure accuratly and repeatable.The hole is on a vertical wall and does not break through the enclosure,there is only about 15mm between the hole and the 2 side walls, i know you get the hand held 90 degree drills but is there a cnc type attachment?
Can anyone help? |
