Thread: Need Help! Possible bad encoder on X servo
Old 03-25-2009, 09:27 AM
bherr bherr is offline
bherr is on a distinguished road
Originally Posted by joejared View Post
You're not looking for an exact match, really, just one that will fit. Both companies sell modular encoders, and you're looking for the right shaft size and encoder counts. You may have to exchange A and B, or if you require commutator tracks, you'll be limited to purchasing them from Renco. Either way, what are the specifications of your motors, including the dimensions of the encoder mounting holes and their thread sizes? Swapping axis' is the usual in field test. With an Oscilloscope you could see the outputs, which are fairly well documented. I have a mini test plug for most motors I work with.
Joe,
the motor is a SEM Type MT 30Z4-61
Max RPM =8300
Volts=140
Pulse Amps=50
Tacho= 9.5
Can you explain A vs B as I have no idea what your talking about.
Ben
