Old 03-25-2009, 02:45 AM
Cartierusm Cartierusm is offline
Cartierusm is on a distinguished road
Help with Quick and Dirty Indexable Endmill Buy
So I've just about finished the Bridgeport CNC conversion and I need some advice on some inexpensive, unless the expensive stuff is well worth it, indexable endmills?
I figure this is the route to go for CNC. I'll be using a heavy mist spray as far as coolant and I think I'll need 3/8", 1/2", 3/4" and 1" Indexable endmills for pretty much everything.
So center cutting? How can you tell if they center cut? I almost always ramp cut anyway so should I be concerned with this?
I'll be mainly cutting steel, stainless and aluminum I take it the holder will work for all and just need a different insert?
Shape, I figure round is for a rounded corner, but whats the cutting differencen between triangle, diamond and square?
And about all the offsets and rake angles and all that jazz.
I don't need a total explanation because I'm sure that's a course all it's own, but if someone can just give me a little direction. Thanks.
