Sorry to hear about the jam you are in. You never mentioned Unipolar drive, and your original motor choice would not have worked with it either.
You are building a commercial machine, that will need to do a lot of work, but using hobby electronics? The problem with hobby electronics is that you end up spending more time trying to make them work than cutting parts. This is fine for a hobby, but EXTREMELY bad for a commercial machine.
The REAL solution for your dilemma is a G540. You should find a way somehow to get this.
Unipolar drive is inferior. But if you MUST continue on this unwise course, maybe Keling will trade your 387s for motors that will work with Unipolar.
What are your power supply specifics? What Voltage and Current will your drive handle?
CR. |
