Originally Posted by davisboys I have a bit of growling on rapid X and Y axis movement. It was suggested that this may be the thrust bearing. Where are they exactly and how do I replace them? Can some one send the schematic diagram detailing the locations? Thanks. |
We have a 1995 15XT and also had a growling problem, ours turned out to be the support bearing on the left side of the table. The service guy removed the bearing and the noise went away, replaced bearing with a new one and all is well again.
you might want to check there first it is a very easy fix.
