Originally Posted by striplar I've just checked my XP machine and it has the CNC Brain installed under 'Unisversal Serial Bus Controllers' as 'CNC Brain'. The driver is accessed from there.
I presume you mean the files that hold the Axis information for that machine. You will find those files at...
Program FilesSafeguard RoboticsCNC BrainMachinesSN[xxxxxxxx]
There should be two folders 'Brain Control Panel' and 'CNC Brain' and I would copy everything there' I believe all of the information is stored as .xml files. |
Cheers.
Originally Posted by striplar When you say that you have recreated the problem, do you also mean that it now doesn't work on either computer? |
Yes, same behaviour on both.
These computers are close to identical, one runs XP home, the other XP pro.
