Originally Posted by striplar As far as I know, you just unplug it for say 1 minute and that's all. I would be inclined to force XP to uninstall the device and see if it will work correctly from scratch.
If you go to device manager and right click the unknown device, you can select 'uninstall' from there. Of course it's always possible that this isn't the device you think it is. I'll take a look at my system later and see how it's presented in the device manager.
Anyway, once you have done this you can click Action in the device manager menu and select 'scan for hardware changes'. You can then point the wizard at the driver to see if that works now. |
I have done that many times, with no improvement. Once I've uninstaled the troublesome usb device driver (with show nonpresent and all that) I plug the CNC Brain back in and the cycle repeats.
Finds a new USB device, asks for a driver location and won't accept the normal CNC Brain drivers.
Where are the setup files located? I want to copy those out and reinstall the CNC Brain software to see if that helps. Then I can copy back in my setup files to avoid all that button clicking.
