CNC Brain Startup Niggles. | | I've finally progressed from bench test to testing on the actual mill, but things are not going soo smoothly.
The first problem I've got is the CNC Brain not being recognised. This is a new computer which been recycled from other duties. I installed the CNC Brain software and it powered up fine, entered and exited the program about 4 times but now it's not showing.
The only option I get is "demo mode", it's not detecting the brain even though the brain internal lamp is on. Swapping USB ports doesn't change things. I'll give it a shot with a different computer (the one I was using for earlier tests) later and see how that goes.
Once I get that sorted, I'll need some help with the setup parameters for each axis.
__________________ My X2 CNC Brain Build: http://www.cnczone.com/forums/showthread.php?t=61345
Gecko G250 wiring errors: http://www.cnczone.com/forums/showthread.php?t=68960 |
