Old 03-21-2009, 05:25 PM
Superman's Avatar
Superman Superman is offline
Superman is on a distinguished road
Probably, the easiest method is to revolve a curve around a line ( axis )
this will give a surface, make sure that it extends further into or past your block to enable trimming surface to curve ( or surface to surface ),
Start off in the front or side view, and create a half section of an umbrella,
the arc is the item to revolve, the stem is the revolving axis.
