tool gouge is not necessarily the fault of the software- we used to see it a lot until it was realized the gouge was caused by a change in direction of the cutter causing it to deflect into the part- it might be better to rough out gouge-prone geometry (eg. inside radi ) first to lessen the drag on the tool as it cuts into that area. Sorry I can't help you with ptc |
