Thread: Using "M" codes
Old 06-17-2003, 05:38 AM
jimglass jimglass is offline
jimglass is on a distinguished road
"I got it"
Thanks, I got it;
Found the misc. I/O setup no problem and found how to toggle through all the options. WOW, learned something today.
However, initially tried pins #1 and #16 and found they only put out 5 Volts which did not trip the 12 volt relays. Pins #14 and #17 put out over 12 v so I used those for the spindle and coolant.
Works great. Hmmm.....would have thought all 4 pins would put out the same voltage??? Also wondering if those relays can switch 24v DC?? If the relays are "solid state" they may not. I always like switching 120V AC with with industrial grade relays.
Thanks again for the help. Sorry Cromwell for the multiple postings. Did not realize that is clearly against the rules and I'll not do it again.
So much to learn and so little time,
Jim
