Originally Posted by Allen123 If you don't want the tool to pick up from one arc to the other, just group them. What I mean is use your contour feature to group / weld / or what ever you want to call it.
When you select the contour for profile machining, the tool will stay in the part till it get to the end of the contour.
I have attached a V23 file where I have done this. Try it and let me know if it helps. |
I am still with ver.21, so I cant use the extension you posted.
