Originally Posted by Claude Boudreau I have tried your suggestion , but the z move on every arc.
So I deleted all the arcs but one that was use to copy a serie again (using .84 value that I got with dimension and point at end of entity)
Re-done the code and it still move Z at every arc. Wonder if its not a tolerance or dimension value not precise enough to make the serie of arcs a flowing chain of entites, as I cant chain select them... |
If this bothers you that much change your Z returns to .025 and then post the program. It will reduce the amount of air cutting but not completely.
__________________ Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com |
